Same MINOTAUR 60
nsamanic
8 Ožu 2010
neznam dali takav model postoji ja nikad nisam čuo za njega, niti ga preko tražilice mogu nać!
Na traktoru piše SAME minotaur 60!! traktor je u odličnom stanju!!
interesira me uputstvo za rukovanje jer mi nema tko objasnit neke stvari, recimo gdje se upravlja hidraulikom???
dali je uvijek ukopčana vuča na sve četiri?
brzine sam skužio, neznam di se ukopčava kardan???
ako itko može pomoć!!!
zbalija
21 Stu 2008
A da staviš koju sliku toga stroja možda bi i ti mogli ljudi pomoći
i reći dali je to samo naljepnica ili neki poseban model...
breza
27 Lis 2007
krivo si napisal pa zato nisi ništa pronašel
SAME MINITAURO 60 4WD
MAX POWER AT ENGINE CRANKSHAFT (kW) 41.8 (hp) 58 at 2200 engine rpm.
MAX POWER AT PTO SHAFT (kW) 42 (hp) 52 at 2200 engine rpm.
MAX CRANKSHAFT TORQUE: 198 Nm at 1490 engine rpm.
ENGINE: SAME 4-stroke, Inline, air-cooled diesel; cylinders = 3, Bore = 105 mm, Stroke = 120 mm, Displacement 3117 cc, Compression ratio = 17:1,
TRANSMISSION: Type = 8 forward, 4 reverse gears.
STANDARD SPEEDS: Forward = 1.88, 3.09, 4.75, 6.59, 7.81, 9.91, 16.64, 25.00 km/h, Reverse = 3.17, 5.21, 11.09, 16.98 km/h, on 14.9 x 13-28 rear tires.
STANDARD TIRES: Front = 9.5/24, Rear = 14.9/28.
TURNING RADIUS: 3.8 m, Ground clearance = 330 mm.
OVERALL DIMENSIONS: Length = 3120 mm, Width = 1670 mm, Height (to top of radiator) = 1290 mm, Tread, Front = 1370 mm, Rear = 1200/1900 mm, Wheelbase = 1960 mm.
WEIGHT (as sold, without ballast): 2030 kg.
BELT PULLEY: Diameter = 230 mm, width = 120 mm, Speeds = 1300 rpm at 2200 engine rpm = 15.656 metres/sec.
PTO: Standard speed = 540, Engine rpm at standard pto speed = 2000, Pto power at standard pto speed (kW) = 33.6, Spline shaft diameter = 34.9 mm, Rotation clockwise viewed from rear.
HYDRAULICS: Reservoir capacity = 11 L, Pump capacity = 350 ml/s, Max pressure 17.5 Mpa, Number remote outlets = 2.
IMPLEMENT ATTACHMENT: Category 1 or 2 linkage, Max lift at hitch point 1830 kg.
CABIN OR ROLLBAR: Rollbar standard, Cabin available.
ADDITIONAL EQUIPMENT AVAILABLE: Belt pulley, Hand control pto, Front and rear weights, Extra low reduction gear, Central pto for mowers, Air brake system for trailers.
SAME MINITAURO 60 2WD
STANDARD TIRES: Front = 7.50/16, Rear = 16.9-28.
TURNING RADIUS: 3.10 m, Ground clearance 430 mm.
OVERALL DIMENSIONS: Length = 3090 mm, Width = 1670 mm, Height (to top of radiator) = 1290 mm, Tread, Front = 1200/1900 mm, Rear = 1200/1900 mm, Wheelbase = 1970 mm.
WEIGHT (as sold, without ballast): 1780 kg.
nsamanic
8 Ožu 2010
puno ti hvala!! spasil si me!!
zwer
15 Ožu 2010
Jel se isplati kupit tako nekaj? Koliko to opće vrijedi? Koliko izdrže takvi traktori? Kakce su cijene dijelova i kakva je mogućnost nabave istih?
Dobri su to strojevi, relativno mali potrošači, ako nisu izrabljeni.
Nisu grubi kao Fiat traktori, pa traže malo pažljivijeg rukovaoca.
Dijelovi su prilično skupi, no ako se pazi, nema potrebe za zamjenom. To s stari modeli pa je svašta moguće očekivati.
Kawa
13 Stu 2010
jel ovaj traktor sa slike prodan, odnosno jel ga je tko kupio jer ga nema u oglasniku...
