Yanmar - ulje i gorivo
slavio
26 Svi 2012
Nasao sam podatke za PREPORUCENA ULJA ZA YANMAR. Mozda ce nekome koristiti:
Ako netko treba prijevod dijela teksta neka mi se slobodno javi.
Engine (Motor)
- 15-40wt Diesel engine oil
Transmission/Hydraulic reservoir (Rezervar ulja za transmisiju i hidrauliku = ulje ulje u getribi)
- sold under many names like -JD303, HyTrans, J10A, J14A, J20A,B,C,D, J27A or a host of other #'s. They will all say "Universal" or "Hydraulic/Transmission" oil.
UPDATE- There are a couple of very well respected Yanmar dealers that have been using Dextron ATF for over a decade with great success- though it has never been recommended in any Yanmar publication that we have found. It should work fine but use at your own risk
Ft Axle (4wd) (Prednja osovina kod modela s pogonom 4x4)
-90wt Gear Oil, 80/90 Gear oil. Really anything that says "gear oil".
Steering Gear Box (Upravljacka kutija = kutija volana)
- 90wt Gear Oil or similar
Coolant (tractors With Water Pump) - (Rashladna tekucina za traktore s pumpom za vodu)
-50/50 any type antifreeze
Coolant (no water pump) - (Rashladna tekucina za traktore bez pumpe za vodu)
-no more than 20% antifreeze in the summer
Grease Zerks (Mazalice za mast)
- any good gun grease
Fuel- (Gorivo)
Any blend of diesel that you can buy from a gas station.
YANMAR HYDRAULIC FILTER SERVICE
INTERVAL - 250 HOURS/EVERY YEAR
TIME REQUIRED -20 MINUTES
Yanmar uses 1 reservoir for both the hydraulic oil and the transmission oil. This oil is a Hydraulic Transmission oil. Never use a simple Hydraulic oil.
The hydraulic pump on all yanmar tractors is very simple. It is basically two gears running together at high speeds to move the oil. These gears must have extremely tight tolerences in order for this to work. Because of these tight tolerences, and dirt or debris will almost always destroy a pump.
Uploaded with ImageShack.us
Because of this, it is important that your oil be clean and your filter or screen be serviced periodically. Not all Yanmar tractors have hydraulic filters. In fact only the '20 series, '02 series, some of the F and Fx series gray market, and some of the US versions have a spin on filter. Most have small tubular screens inside the transmission housing that filter the oil.
If your tractor has a spin on filter, replacement is a breeze.
1 - Be sure that you have a replacement filter on hand. These are not filters that you will find at a local parts store. Please check our sponsors for a replacement hydraulic filters.
2 - Using a filter wrench or channel lock plyers, remove the oil filter. As the oil is draining out of the filter housing, remove the drain plug. This is located just below the rear axles. There may be two or more plugs that you will need to remove in order to get all of the oil drained. Use a large drain pan as it may hold many gallons.
3- If your tractor has the screen type filter, after the oil has drained, locate the screen. The screen will always be in the transmission housing. It will usually be on the directly on the opposite side of the large hydraulic suction line that goes into the right (sitting on the seat) side of the transmission. You will need to remove a 2-4 bolt plate that holds this filter in. The filter may also be directly behind the large suction line. To remove this filter you will need to remove the rubber hose connection thatcouples the two sections of steel hyd line together. Then remove the 3-4 bolt plate where the line goes into the transmission. The screen will be behind that plate. If the screen is in none of these places, it will be behind a 2-3 bolt plate at the very botton of the transmission. Refer to your parts manual or operation manual for exact location.
4 - Clean the screen with a carburator cleaner or fresh diesel.
5 - Re-install screen and cover. Re-fill with the correct amount of Hydraulic Transmission oil. Never use a simple Hydraulic oil. Check periodically with the dipstick or check your Yanmar operation manual for your tractor.
6 - Start tractor and check for leaks.
Neki modeli Yanmara ( to su traktori s brojem 20 u oznaci, s brojem 02 i neki od F i FX traktora) imaju Filter za navrtanje (izvana).
Taj filter je obicno "CAPA, CP 145 VL-35" (Filtracija 35 mikrona).
Ovaj filter moze se zamjeniti sa filterom "NAPA GOLD Hydraulic Filter No. 7089"
slavio
26 Svi 2012
U medjuvremenu nasao sam nove podatke za ulja i filter za Yanmar:
ZAMJENSKI FILTERI ZA CAPA, CP145VL35
Dimenzije filtera CAPA, CP145VL35:
Height 137 mm
OD/Width Max. 97 mm
Thread: 1 ½ - 16 UN
Popis filtera koji se mogu upotrijebiti u zamjenu za CAPA, CP145VL35:
John Deere RE27284
FIN-FH50766
WIX Filter# 51205
Ac Delco PF1237, PF2025, BALDWIN BT371, BT371MGP, DONALDSON P167830, HF 30399, HF6127, HF 6281, HF6625, HF6634, FLEETRITE HFR86127, HFR86281, HFR86625, HFR86634, FRAM P3779, P7025012536, 25014353,
IHC1282428C1, 1282428-C1, IN-LINE FILTERS FBWBT371, FBW-BT371, FINFH50766, FIN-HF50766, KALMAR 920130001, KRALINATOR L1205, LUBERFINER LFH8395G, PALL HC7400SKT4H, HC7400SUT4H, PUROLATOR FACET3010, SPH20054,SPH9795, WIX 51205, 51229, 51413, 551205, 551229, 551413, WOODGATE WGPT7404, ZINGA ZHE10
OZNAKE “Univerzalnih Hydraulic-Transmision” ulja:
UTTO – Universal Tractor Transmision oli
UTHF – Universal Tractor Hidraulic Fluid
TDH - Transmision Hidraulic Fluid
PRIMJERI UPOTREBLJIVIH ULJA
MAZIVA ZAGREB D.O.O,
ZAGREB/HR
INA TRANSHIDROL JD 50
AMS-OIL
Synthetic Tractor Hydraulic/Transmission Oil SAE 5W-30
For All Weather Performance in Farm and Commercial Equipment
Formulated for combinations of transmission, hydraulic systems, final drives, power take-off systems and wet brakes. Engineered specifically to meet the tough applications of heavy-duty farm and industrial equipment as well as commercial and residential lawn tractors. Ideal for lawn tractor hydrostatic transmissions.
ChevronTexaco TDH® SS Oil
Texaco TDH Oil SS (Transmission-Differential-Hydraulic Fluid) is a truly unique, high quality, synthetic, multifunctional fluid, specially formulated for use in transmissions, final drives, wet brakes, and hydraulic systems of tractors and other equipment employing a common fluid reservoir.
Shell Donax TD (10W-300)
Ili nova oznaka: SPIRAX S4 TXM
High performance tractor transmission oil
Premium “universal tractor transmission oils” (UTTO) designed for use in
transmissions, hydraulic systems, oil immersed brakes and other ancillary systems
fitted to agricultural tractors and off-road equipment. Donax TD are recognised by
leading agricultural equipment manufacturers and suitable for use in most modern
equipment.
POPIS PROIZVODJACA I OZNAKA UTTO - ulja
Lubricant class 03E
Universal Tractor Transmission Oil (UTTO)
Continued ZF Friedrichshafen AG / List of lubricants TE-ML 03, edition 01.04.2012
Manufacturer (03E) Trade name (03E)
ADDINOL LUBE OIL GMBH, LEUNA/D ADDINOL UTTO SAE 10W30
ARAL AG, BOCHUM/D ARAL FLUID HGS 10W-30
AVIA MINERALÖL-AG, MÜNCHEN/D AVIA HYDROFLUID DLZ
BAYWA AG, MÜNCHEN/D TECTROL UTTO - HF
BP INTERNATIONAL, PANGBOURNE, READING/GB ADAMOL TRANSMISSION-TRAKTOROIL SAE 10W-30
BP INTERNATIONAL, PANGBOURNE, READING/GB BP TERRAC SUPER TRANSMISSION 10W-30
BP INTERNATIONAL, PANGBOURNE, READING/GB BP TERRAC SUPER TRANSMISSION CVT 10W-30
BP INTERNATIONAL, PANGBOURNE, READING/GB BP TERRAC SUPER TRANSMISSION CVT 80W
BP INTERNATIONAL, PANGBOURNE, READING/GB BP TRACTRAN TF 10 10W-30
BP INTERNATIONAL, PANGBOURNE, READING/GB BP VANELLUS AGRI SUPER TRANSMISSION
BUCHER AG LANGENTHAL, LANGENTHAL/CH MOTOREX UTTO CF
BUCHER AG LANGENTHAL, LANGENTHAL/CH MOTOREX FARMER POLY 304
CASTROL INTERNATIONAL, PANGBOURNE READING/GB CASTROL AGRI TRANS PLUS 10W-30
CASTROL INTERNATIONAL, PANGBOURNE READING/GB CASTROL AGRI TRANS PLUS CVT 10W-30
CASTROL INTERNATIONAL, PANGBOURNE READING/GB CASTROL AGRI TRANS PLUS CVT 80W
CASTROL INTERNATIONAL, PANGBOURNE READING/GB CASTROL AGRI TRANS PLUS SAE 80W
CATERPILLAR INC., PEORIA/USA CATERPILLAR MULTIPURPOSE TRACTOR OIL (MTO) 10W-30
CEPSA LUBRICANTS S.A., MADRID/E CEPSA AURIGA TE 55 (SAE 10W-30)
CHEVRONTEXACO GLOBAL LUBRICANTS, SAN RAMON/USA CHEVRON 1000 THF (SAE 10W-30)
CHEVRONTEXACO GLOBAL LUBRICANTS, SAN RAMON/USA TEXACO TDH OIL (SAE 10W-30)
CHEVRONTEXACO, GHENT/B TEXTRAN TDH PREMIUM
CLAAS KGAA MBH, HARSEWINKEL/D CLAAS AGRISHIFT GA 12
CONOCOPHILLIPS COMPANY, HOUSTON/USA 76 HYDRAULIC/TRACTOR FLUID
CONOCOPHILLIPS COMPANY, HOUSTON/USA KENDALL HYKEN 052
DE OLIEBRON B.V., ZWIJNDRECHT/NL TOR GEAR OIL UTTO
ENGEN PETROLEUM LTD., CAPE TOWN/ZA ENGEN AGRIFLUID
ENI S.P.A. REFINING & MARKETING DIVISION, ROME/I AGIP ROTRA MULTI THT
EXXON MOBIL CORPORATION, FAIRFAX, VIRGINIA/USA MOBILFLUID 424
EXXON MOBIL CORPORATION, FAIRFAX, VIRGINIA/USA MOBILFLUID 426
FUCHS PETROLUB AG, MANNHEIM/D AGRIFARM UTTO MP
GAZPROMNEFT-LUBRICANTS, LTD, MOSCOW/RUS G-SPECIAL UTTO 10W-30
GINOUVES GEORGES SA, LA FARLEDE/F YORK 676 10W30
GUANGXI LIUGONG PREMIUM-GRADE LUB. OIL LTD./CN LIUGONG DEDICATED TRANSMISSION OIL(10W30)
GULF OIL INTERNATIONAL, PITTSBURG/USA GULF MPTF 10W-30
JOHN DEERE, MANNHEIM/D JOHN DEERE HY-GARD
JOHN DEERE, WATERLOO/USA JOHN DEERE HY-GARD
KUWAIT PETROLEUM R&T B.V., EUROPOORT RT/NL Q8 T 2000
KUWAIT PETROLEUM R&T B.V., EUROPOORT RT/NL Q8 T 2100
KUWAIT PETROLEUM R&T B.V., EUROPOORT RT/NL Q8 T 2200
LLK FINLAND OY, HAMINA/FIN TEBOIL WETOL
MAZIVA ZAGREB D.O.O, ZAGREB/HR INA TRANSHIDROL JD 50
OK NEDERLAND, STAPHORST/NL OK HTU PLUS
OK NEDERLAND, STAPHORST/NL QUINTOL REAR AXLE FLUID F.I.D.
PAKELO MOTOR OIL S.R.L, SAN BONIFACIO (VR)/I PAKELO UTTO FLUID 4D SAE 10W/30
PANOLIN AG, MADETSWIL/CH PANOLIN JD 303
PETROBRAS DISTRIBUIDORA S.A., DUQUE DE CAXIAS/BR LUBRAX UNITRACTOR
PETROGAL S.A., LISBOA/P GALP TRALUB 807S
PETRONAS LUBRICANTS INTERN., KUALA LUMPUR/MAL AKCELA NEXPLORE (SAE 10W-30)
PETRONAS LUBRICANTS INTERN., KUALA LUMPUR/MAL AMBRA MULTI G
PETRONAS LUBRICANTS INTERN., KUALA LUMPUR/MAL ARBOR MTF 10W-30 (SAE 10W-30)
PHI OIL GMBH, ST. GEORGEN BEI SALZBURG/A GEAR OIL UTTO SILVER 10W30
RAVENSBERGER SCHMIERSTOFFVERTRIEB GMBH, WERTHER/D RAVENOL GETRIEBEÖL UTTO
REPSOL YPF LUBRICANTES Y ESPECIALIDADES, MADRID/E AGRO ORION SAE 10W30
SAME DEUTZ-FAHR DEUTSCHLAND GMBH, LAUINGEN/D DF UTTO 10W30
SAME DEUTZ-FAHR DEUTSCHLAND GMBH, LAUINGEN/D SDF UTTO 10W30
SASOL OIL, RANDBURG/ZA UNIVERSAL TRACTOR TRANSMISSION OIL 68 (SAE 80W)
SAVITA OIL TECHNOLOGIES LIMITED, MUMBAI/IND SAVSOL 315 HAT
SHELL INTERNATIONAL PETROLEUM COMP LTD, LONDON/GB SHELL DONAX TD
SHELL INTERNATIONAL PETROLEUM COMP LTD, LONDON/GB SHELL DONAX TDS 10W-30
SHELL INTERNATIONAL PETROLEUM COMP LTD, LONDON/GB SHELL SPIRAX S4 TXM
SHELL INTERNATIONAL PETROLEUM COMP LTD, LONDON/GB SHELL SPIRAX S6 TXME
SRS SCHMIERSTOFF VERTRIEB GMBH, SALZBERGEN/D SRS HYDROFLUID N
TOTAL LUBRIFIANTS S.A., PARIS/F ELF TRACTELF BF 16
TOTAL LUBRIFIANTS S.A., PARIS/F TOTAL DYNATRANS MPV
TOTAL LUBRIFIANTS S.A., PARIS/F TOTAL DYNATRANS MPWB
UNIL OPAL, SAUMUR CEDEX/F FLUID VO
VALVOLINE EUROPE, DORDRECHT/NL VALVOLINE UNITRAC 80W
VOLVO CONSTRUCTION EQUIPMENT, ESKILSTUNA/S VOLVO WETBRAKE TRANSAXLE OIL (WB101)
WOLF OIL CORPORATION N.V., HEMIKSEM/B WOLF UTTO 170 VOLVO BM SAE 10W30
Mozda ovo nekome posluzi. Ja sam potrosio puno vremena skupljajuci ove informacije.
Srdacan pozdrav
Slavio
davidescuvkci
12 Srp 2016
ekipa,trebam pomoć! imam yanmara ym1500 , fali mi ulja u hidraulici,jer mi se čuje pumpa kad dižem i spuštam... kupio sam hidraol,ali muči me neznam gdje se sipa.. ima kraj mjenjača žuti čep,ali nešto mi govori da se tu sipa ulje za mjenjač hipenol... a čep za hidrauliku nikako nemogu naći... molim pomoć ako netko zna što mi je činiti
davidescuvkci
12 Srp 2016
nisam dosada... tek sad vidim tu stranicu, ali opet mi ništa nije jasno... jer jednostavno nema na traktoru čepa za hidrauliku... ima za ulje motora, ima to kod mjenjača, pretpostavljam da je to za mijenjač,ali za hidrauliku nevidim... kad dođem kući poslikat ću pa ću probat staviti ovdje
e tako , slikaj ga ljevu i desnu stranu pa bude lakše nama koji ne poznaju model
Razinekop
10 Pro 2013
Na mome traktoru Iseki TU 1600 ,zajedničko je ulje za getribu i hidrauliku!
Ja koristim INA Transhidrol 45-60.
Traktorce
29 Lis 2016
Zdravo.treba mi jako pomoc imam yanmar fx 24 i trebao bi uraditi servis ulja komplet motora,hidraulike prednjeg kardana ..p.vuce ,servo koja ulja za sve to da sipam kontam da su razlicita .hvala unapred na pomoci
Servis celog traktora sto se tice ulja....
Re: YANMAR , i ostali japanski traktori
Pretpostavljam da tvoj nije mlađi od 1993god.
U motor bi trebalo iči ulje za dizelske motore mineralno 15w40 recimo ina super 5 ili Turbo,shel rimula 15w40.
U getribu neznam,to bi trebao nazvati ovlašten servis i pitati.
A u prednji dif hipoidno ulje,neki od hipenola samo treba saznati točnu gradaciju.
Isto kao i za servo volan,pretpostavljam hidrol.
Traktorce
29 Lis 2016
Ok..hvala puno ako jos neko zna nesto nek pise,znam da u menjac ide neko crveno ulje to sam video.ee sad me jos interesuje menjacko ulje i za hidrauliku izgleda da je isto .hvala vam unapred
Ima li ko kakav br.od servisa za yanmar traktore ili neko detaljnije objasnjenje u vezi ulja sa svim oznakama i vrednostima.
Traktorce
29 Lis 2016
Zdravo trebam pomoc,imamyanmar fx24d koje ulje sipati u motor koje u menjac i hidrauliku i koje u prednji pogon.hvala
Ovo si pitanje postavil već prije i u nekoliko tema.
Neke odgovore si već dobil.
Pričekaj još malo i nema potrebe svako malo postavljati isto pitanje.
wwuki5
6 Velj 2010
Moje iskustvo u protelih 10 godina korištenja yanmara:
Motorno ulje = super 3 za dizel , zamjena filtera i ulja svakih sto sati ili jednom godišnje i nikad neće biti problema .
Mjenjač i hidraulika su zajedno i ide ATF .
prednji pogon hidrol tj . što gušće to bolje :(hi):
ostalin pokretni djelovi totmast :(rofl):
Kažu tko podmazuje taj i vozi :tractor::eek::
Prednji pogon Hidrol??? Zakaj?
Bar Transhidrol ili obični Hipenol ili motorno ulje. Hidrol mi nema logike u zupčaničkim prijenosima.
Sada bu puknuti pital kak ulje zna jel podmazuje zupcanike ili cilindre...
Ulje nezna, ali zupčaniki znaju :)
wwuki5
6 Velj 2010
Moja greška u pisanju, ali ipak sam napisao što gušće to bolje:icon_rofl:
Ne znači to nikaj. U mojim traktorima je ulje tipa TH, a "rijetko" je kak voda.
da niste otjerali onog kaj zna sve o uljima sad bi vam znal objasniti da je hidrol bolje od svega nabrojenog
