Zahrđala inox bačva
18 Svi 2013
bio sam dobar u kemiji pa sam malo istražio. ima par koraka, ali na kraju se dođe do sumporne kiseline.
Sulphur dioxide dissolves readily in water, which is then classed as a weak reducing acid (sulphurous acid H2SO3). Theoxidation of sulphur dioxide can be assisted by chlorine. Sulphuric acids and hydrochloric acids can be formed in aqueous (water) systems.
As a dry or liquefied gas, sulphur dioxide does not tend to be aggressive towards stainless steel. Grades with more than 18 to 20% chromium should be resistant to dry sulphur dioxide.
Corrosion risks to stainless steel
A 20% concentration of sulphur dioxide dissolved in water at 20 degC can be expected to give a corrosion rate between 0.1 and 1.0 mm/year on stainless steel 304 types, but a rate below 0.1mm/year on stainless steel 316 types and hence is 'mildly' corrosive.
If exposed to the air sulphuric acid (H2SO4) is formed from the sulphurous acid and so sulphur dioxide dissolved in water can be hazardous, where sulphuric acid has been allowed to form.
In damp vapours where oxidising conditions exist sulphur dioxide can be aggressive, depending on the dew points of acid and water at the service temperature under consideration.
Source: Zhejiang Yaang Pipe Industry Co., Limited
rudamaca
6 Ruj 2007
Tak več funkcionira. dioksid i voda ,pa rezultat i zrak i dobiješ inoxicu za crno vino :icon_eek:
Neznam od čega ih sad delaju ,poklopaca je bilo nekad dvije vrste, obični i poklopac za vrenje (sa rupom) od nešto otpornijeg inoxa.
18 Svi 2013
na svaki poklopac možeš napravit rupu. tak delaju. isti materijal. ali nije mi jasno koliko tog dioksida mora biti u vinu da bi uništilo spremnik u roku 2 tjedna...
tatkodvd
2 Pro 2011
"sumporov dioksid i voda zajedno čine sumpornu kiselinu"
Sve pet dobro je dal diagnozu ali ak je enolog točno to rekel ima jedan .Iz kemije.
Tačno 7 razred osnovna škola.
enolog nam je pomogao. on je to već vidio. ako iz vina izađe mnogo sumporovog dioksida, on se veže sa vodom koja se kondenzira na hladnom rubu spremnika prilikom vrenja. sumporov dioksid i voda zajedno čine sumpornu kiselinu koja nagriza inox.
Dobije se sumporasta kiselina H2SO3, što nije ni blizu sumporne kiseline H2SO4 ili kako je još zovu sulfatna kiselina.
Sumporna i sumorasta kiselina imaj samo slično ime. Sumporna kiselina je veoma otrovna za korištenje u ljudskoj ishrani i nema teorije da se dodavanjem sumpora obično vinobran (kalijev metabisulfit K2S2O5) da sa vodom gradi sumpornu kiselinu. Volio bih vidjeti tog hemičara koji će to dokazati.
A to što je negrizlo Inox bure to ti nije pravi inox, obično je neka imitacija. Inox koji se koristi mora biti kiselo otporan.
Vrati do bure i reklamiraj ga.
Evo ima i fino napisano o kiselinama:
https://sr.wikipedia.org/wiki/Sumporasta_kiselina
https://hr.wikipedia.org/wiki/Sumporna_kiselina
