Zetor 6245
J
jokapz
Re: stari heroj zetor 6245
Zetor 6245 to ti je 62 konja.......
toma84
10 Velj 2008
Zetor 6245
General tractor information:
Manufacturer: Zetor
Model: 6245
Type: Farm/Agricultural tractor
Years produced: 1985 - 1992
Total built: -unknown-
Factory: Brno, Czechoslovakia
Original price: $17000 (1992)
Tractor power:
Drawbar (rated): 47 hp [35.0 kW]
PTO (rated): 53 hp [39.5 kW]
Engine:
Manufacturer: Zetor
Fuel: diesel
Cylinders: 4
Bore/Stroke: -unknown-
Displacement: 210.9 ci [3.5 L]
Compression: -unknown-
Rated RPMs: -unknown-
Cooling: -unknown-
Torque: -unknown-
Firing order: -unknown-
Transmission:
Type: sliding gear
Forward: 10
Reverse: 2
Mechanical:
Chassis: 4x4 MFWD 4WD
Steering: -unknown-
Brakes: -unknown-
Capacity:
Fuel: 18.5 gal [70 L]
Coolant: 14.5 qts [13.7 L]
3-Point Hitch:
Rear Hitch Category: I,II
Rear lift: 5300 lbs [2404 kg]
Power Take-off (PTO):
Rear PTO: independent
Rear speed (RPM): 540, 1000
Hydraulics:
Type: open
Capacity: 26.5 gal [100 L]
Total flow: -unknown-
Valve flow: 8 gpm [30.3 lpm]
Pressure: -unknown-
Valves: 2
Tires:
Ag front: 11.2-24
Ag rear: 16.9-30
Dimensions:
Weight: 7400 lbs [3356 kg]
Wheelbase: 87.8 inches [223 cm]
Length: -unknown-
Width: -unknown-
Height: -unknown-
Ground clearance: -unknown-
J
jokapz
Evo i Zeko je uzeo bolovanje. Upravo sam ga otero u servis. Al nije traktor kriv za kvar. Prije par godina osto je bez ulja u mjenjaču i napravio jedno desetak km pod gadnim teretom. Od tad mi je cvrčo neki ležaj u rikvercu al sam u sporim i pod velkim opterečenjem. Al sad mu je dojadlo. Jebiga vrtio se je tako godinama al sad se izgleda rasuo....
A
actros
ej jokapz jesi probao sa zekanom radit sa roto-drljačom? ako jesi zanima me kako to ide jel ima dosta mišića... ?
J
jokapz
S rotodrljačom nisam radio al mislim da bi mogo vuči nekaku od 2 do max 2,5 m sve zavisi o zemlji. Kod mene on dosta radi sa kardanom tj. PVT i za 62 konja jako je jak na kardanu. Usuče kardan al motor neposustane....
Š
šlep
Ima moj prijatelj iz susjednog mi sela 6245, 88.g. i on vuce s njim 3 m rotodrljacu :shock: ima i 2,5 m s kojom ide na tezim tlima. Ja kad sam vidio da radi s 3 m (neka lagana Maschio rotodrljaca) ostao sam :shock: ,istina da mu je tesko i da mu je auspuh tijesan ali radi...izgleda da je stvarno jak na kardanu. :scratch
Ranko
28 Lip 2008
Šezedeset dvojka nije loš traktor samo što puno troši. Imao ga jedan komšija pa ga morao prodati zbog velike potrošnje. Za mene je Steyr prava zvijer od traktora. To je nepoderiva masina, nijedan drugi nemoze sa njim u na crtu.
J
jokapz
hmm... Neznam baš da je Zetor velik potrošač. Kažem to jer ga imam. On je malo veči potrošač od Deutuza al daleko manji od IMT..... Zeko u oranju popije oko 9 l po jutru bar moj što stvarno nije puno :roll:
Pa kak se ponaša s time, jel može vuči??
J
jokapz
puna kapa... čim skontam kak se stavlja video stavim pa vidite....
e daj savi video..
prvo moras ne yutube i onda možeš na forum..
koliko cm to vučeš i kojom brzinom??
J
jokapz
a znaš kak je neđe nekak s ovim pačijim nogama negdje 25cm jer tad radi najbolje ak je ravno onda 1 brzom a ak ima brda 5 sporohodna. kad skinem pačije noge ostanu sam pera onda idem izmedu 30 i 40 cm al onda 4 spora i pun gas.
Marko355
16 Lip 2008
Kako zakon, kolko taj radi ako ima 10000 rh, a moj ima oko 35 godina a ima 2900 sati, još malo če 3000!!!
abrkili
26 Ožu 2007
ursusc360 kaže:
onda slabo radi...ljenčari.. :p
Marko355
16 Lip 2008
pa može se reč, po zimi ga uopče nepalimo...
abrkili
26 Ožu 2007
eh,pa da ne bi ručno čistio snijeg,ralica i opiči po snježini...a i treba đubre izvest kad čistim boksove i tako..ili bar malo upalit da se ne smrzne baš.. ;)
