Češnjak / bijeli luk
zokii
17 Lis 2009
Neka autohtona domača sorta i na drugoj slici se vidi imam par komada nekog ogromnog češnjaka što izgledom podsječa na poriluk, a glavica je jako velika i bečka mu naraste do 2 metra u vis... to sam dobio jesenas odsusjeda pa budem slikao kada naraste...
    82.8 KB · Pregleda: 161
    82.4 KB · Pregleda: 196
Vinkovci
10 Velj 2013
6 ACROBAT MZ WG UP/I-320-20/06-01/223 BASF Agro B.V. Arnhem (NL) Zurich Branch
11 AFALON DISPERZIJA UP/I-320-20/08-01/408 Agan Chemical Manufacturers Ltd.
12 AGIL 100 EC UP/I-320-20/98-01/153 Agan Chemical Manufacturers Ltd.
167 DACONIL 720 SC UP/I-320-20/06-01/149 Syngenta Crop Protection AG
200 DIFCOR UP/I-320-20/06-01/232 GLOBALCHEM N.V.
208 DITHANE DG NEOTEC UP/I-320-20/03-01/113 Dow AgroSciences V.m.b.H
217 "DUAL GOLD 960 EC" UP/I-320-20/97-01/313 Syngenta Crop Protection AG
249 FAZOR UP/I-320-20/08-01/396 Chemtura Netherlands B.V.
261 FOLICUR EW 250 UP/I-320-20/97-01/22 Bayer CropScience AG
268 FORCE 1,5 G UP/I-320-20/04-01/205 Syngenta Crop Protection AG
374 LASER UP/I-320-20/01-01/275 Dow AgroSciences V.m.b.H
384 LINUREX 50 SC UP/I-320-20/08-01/411 Agan Chemical Manufacturers Ltd.
472 ORTIVA UP/I-320-20/08-01/122 Syngenta Crop Protection AG
524 PROPLANT UP/I-320-20/02-01/167 Agriphar S.A.
541 QUADRIS UP/I-320-20/08-01/96 Syngenta Crop Protection AG
575 RIDOMIL GOLD MZ PEPITE UP/I-320-20/09-01/321 Syngenta Crop Protection AG
584 ROGOR 40 UP/I-320-20/92-01/406 Cheminova A/S
600 SCORE 250 EC UP/I-320-20/06-01/241 Syngenta Crop Protection AG
606 SELECT SUPER UP/I-320-20/01-01/266 Arysta Lifescience S.A.S.
741 STOMP 330 E UP/I-320-20
dursbana NEMA!!!! Kao ni mnogih drugih............OTVORITE F I S na min. poljopr. i tamo možete pronaći sve što vas zanima vezano za pesticide
Vinkovci
10 Velj 2013
16.2 prvi tretman protiv muhe!!!!! Meni nije jasno kako to da ljudi sade veće površine češnjaka a ne prate muhu sa žutim pločama što je najbolje!?
Vinkovci
10 Velj 2013
Marko355 Skroz normalna pojava koja se dešava prilikom nicanja proljetnog češnjaka koji je sađen sadilicom !!!List mu ostane ispod jedne ovojnice , ili je pao u zemlju kontra pa malo teže izrasta
Marko355
16 Lip 2008
Hvala na odgovoru! Ako si ti Pero R. onda je taj luk sađen vašom sadilicom. Tata kaže da se luk poprilično popravio, nemam vremena nikako da odem i poslikam...
Loncin
31 Kol 2011
Ne znam kako je kod vas ali kod mene je problem ljiljanova zlatica...jede mi luk...ne znam kako je unistiti , rijesiti je se ..
Loncin
31 Kol 2011
Cini se da je moja najveca greska ove godine-eko proizvodnja...
Muhu smo prezivjeli bez problema...
Ali eto sad tih ljiljanovih zlatica..
Par komada zarazenih hrđom...
Plamenjaca...
Uglavnom sve moguce se okomilo bas na moj cesnjak...
Vinkovci
10 Velj 2013
Loncin sokole moj lipi samo ti nastavi sa eko sranjima!!! Dragi moji češnjak se može proizvoditi u eko verziji samo za svoje potrebe , ali komercijalno ni slučajno. Ja sam posadio 2.3 ha češnjaka i u bašči tri reda koje sam mislio vaditi sada za Uskrs kao mladi . Taj u bašči mi je napala muha i od 50 biljki izvadio sam 20....................
itp
12 Svi 2008
na temu eko-sranja, jel ikome palo napamet da je sva kemija oblik droge i stvara ovisnost. bilo čovjeka, bilo zemlje. što dalje, to je više treba... i što se više troši, to je slabija. i tako u krug dok se sve ne potruje. malo je neozbiljno i nepristojno nečiji rad ili životna opredjeljenja nazivati sranjem. pogotovo kad što pola ovih kemičara prodaju priče o zdravoj hrani...
a kako je krenulo s ovim češnjakom, opet će se pokazat da su najdohodovnije kulture pšenica i kukuruz. sad je na redu ekspanzija krumpira :icon_fU: mislim da će ga za godinu-dvije biti ko češnjaka :D:
Vinkovci
10 Velj 2013
Ok!! Ispričavam se što sam uvrijedio nekoga ili nečiji rad i trud.
Moje je mišljenje da je to uzaludan trud u koliko se proizvodi u komercijalne svrhe!
Ja razumijem što je kemija i znam da je puno bolesti i nametnika krenulo upravo iz farmacije(bilo koje). Hrvatska ima 20x manje dozvoljenih sredstava nego ostatak EU u proizvodnji češnjaka , i u koliko se samo pridržavamo FIS-a mislim da to nije kritična količina pesticida. Još jednom želim reći da poštujem svakoga i svačiji način rada i proizvodnje te ne poričem kvalitetu EKO proizvoda!!
Loncin
31 Kol 2011
Nisam veliki proizvodac niti je to velika kolicina ali za mene je puno...
Muhu kao sto sam rekla smo prezivili odlicno, za vikend me nije bilo doma i u tih par dana vratim se i imam sta vidjeti...
Ne znam da li ce se hrda i plamenjaca siriti, da li uopce postoji sansa da od toga nesto bude...
Kisa pada non stop i ne dozvoljava spricanje niti nista...
Vinkovci
10 Velj 2013
I hrđa i plamenjača se šire u polju kada je vrijeme toplo , dok su uvjeti za njihov razvoj upravo sada idealni
Loncin
31 Kol 2011
evo moje muke....na slici je ljiljanova zlatica koja jede luk
goran1985
5 Ožu 2013
Mozes bakrom suzbit hrdju, ja mislim da je bakar dozvoljen u eko proizvodnji. U eko proizvodnji pogotovo treba ulozit napora da nesto ostane zdravo, stvorit uvjete za to. A ne kako to najcesce bude - izgovor za lijenost...
Pero, znam da si pricao da prskas Folicurom, ja nisam nikad i sad kad vidim prognozu vremena puno mi je zao. Kazi mi ima li smisla sada tretirati cesnjak s njim?
Evo jedna fotografija ranog, ima vec glava od 7-8cm:
