KULTIVATORI - špartači
ionstegarus
15 Lip 2015
Pozdrav,
Imam stari OLT Osijek MKPO 2/4/6 Hrvatska i ne znam koji je točan položaj kotača koji se bavi / trenira gnojivo.
Možete li mi reći je li t točan položaj (u priloženim slikama) kotača koji uključuje / trenira gnojivo?
Thank you
Hello,
I have an old OLT Osijek MKPO 2/4/6 Croatia and i dont know which is the corect position of the wheel which engages/trains the fertilizer.
Can you tell me if t is the correct position (in the attached pictures) of the wheel which engages/trains the fertilizer?
Thank you
    66.9 KB · Pregleda: 118
    66.6 KB · Pregleda: 102
You have two possible settings: left on the driving wheel shaft are smaller and bigger sprocket, and on upper shaft is opposite: bigger and smaller sprocket.
Put the chain in line with the sprockets: small bottom-big top or opposite. On that way you'll have smaller fertilizer distribution capacity, but you can better adjust it on the scale.
If this distribution capacity is too small, move chain on another setting: bigger botom and smaller upper sprocket.
If you can count tooth on the sprockets and diameter of the driving wheel, maybe I can give you the table of fertilizer delivery (from SKPR seed drill).
matijavz
13 Pro 2015
Zna li netko gdje bi se mogli kupiti oni poklopci na mehanizmu koji tjera gnojivo za IMT kultivator??
komer
1 Srp 2008
Ja kupio u poljostroju.ako se ne varam 15ak kn su bili.
Ako nemaš mogu ti kupiti i poslati,samo mi podatke javi na pm i koliko ih trebaš;)
ionstegarus
15 Lip 2015
Thank you very much,
I'm confused (puzzled) regarding the correct position of the wheel support. please see the attached picture. What is the correct position A or B?
thank you
    14.5 KB · Pregleda: 78
matijavz
13 Pro 2015
Tnx na info!
Svaka cast, nije bas cesto da netko ponudi pomoc...budem riješio bitno da znam di ima.;)
mali.alen
13 Kol 2012
thank you
I would say position A
is correct
Zetorboy
12 Velj 2010
Zasto su oltovi kultivatori jetiniji od imtovog i po cemu su onda i bolji?
mali.alen
13 Kol 2012
I would say because my friend has the same and it is positioned like A. For other things i dont know. Sorry
Zoki ticić
19 Stu 2012
What adjustments you need to do?
When I was cultivating the corn I set the duck legs approx. 12cm from both sides of corn on each rows, If you have 2 row seeder than you must have 2 row cultivator. Seeder can have more rows than cultivator but the cultivator cannot be bigger than seeder because its hard to get perfect row distance on row which depend on driver and than you have a problem.
Poslano sa mog LG-H818 koristeći Tapatalk
Marko355
16 Lip 2008
Moj dobio brzinski remont.
Stavio sve nove motike, do sljedece sezone ce biti velike kutije na njemu, nisam stigao ove sezone.
    65 KB · Pregleda: 120
    83 KB · Pregleda: 123
    82.9 KB · Pregleda: 144
    82.5 KB · Pregleda: 117
jlukaci7
1 Velj 2012
Da su kremšnite to bi prepoznal:wink::icon_mrgreen:
