Općenito
zwer
15 Ožu 2010
slike od jučer naveče
reprezentativni dio s jako malo mraza
fpmyGvHQejIy9WpjnHadL1LoeugrVLdVXAe1wbu7bQsjlXmZX7p8HjzjgrN-as1TDDtF7_SvNckJ8n_1Mch9QesiaS0k44L104Bw5Xfyub9aNfdqPDL6eA1onpqNSQv1oA8j4DskXW5jGDZKnRsvZ7VU69emJZ1sHySjKF220zZ_K-0IYzgQLJvVfHzrJVQuaTpcpl0W85Lhqpq3_WpTxIB-kTkPl719tm6y5vH-CQuuUbQjVTsloaZM-9O-OKmOkkRjO5_EGNbdDiPQ2tXPP6tfQXArHCzG4QGTDSTqgjJ408rQCXuHmkseZSgKyQEP6Vd0Lps7a633K3hkbApFyaXpdLpESt51fOUhOeK1lc-U-O17nsvh0tLJSIqSFBA0QxbvqhmBnNosSZbLTby9L6Coh0sQP-W-JVWJJGVg47AmXOfCjANS4Q46MlnQLR6fv8qsagWUJb4OPMDW9D2Jbx3-xc0LBwCgu5qRS1Td5YrVD4DzcC8rCs1CimVkGpzFdtGBeRQ647oAHhnd7xMq-tVHes7kEnlkt91bNIazUXsXWv4RyOKAF8MN8MYRUsOcgHV8KNxo9EET3Hv_PpwLHTHYxN3EJ16BVm_lbNmxHiAaK54lZw=w1680-h945-no
rS6gtSBJ9gI3g7_HrgJhzgvuN3TYmg2xAwQiLv-xCnd_yfqpdVAf5YSQvjRPrRaSbWagZAq48yUkb64LKfk93whNtM0bvVkkjWwvgC1QZ02n8UaaQ_lSTxz_mCLZMJEjCT_uLMNk3cUyPG1P4wMb2Ka_7L9e9vQ5OJrf9bQ793m0-7w4P-UaW2IwZnkQw2omdleqLGMYIRe6QTDccmPNQ8ZSooCPoqzUF3Pd_RUgWQywyH7WyS19lhmfrbGQV7CUuOpo7SDr94-lgAUXFN95Ndjrp_24hbb043tvLsegRpJAl6FjqIGBfWvItIOg575LjYuJEr9e00PVEBZJsMic7MBj7n-FBcz7ChTzh3xudt3S7ZfNIhYzg2H0AwAHkRAxUd5s3ASwKVy8M_8YhyYK5C8hz2lo_oMMJL3Ci6Wvp_Pay4x7M2Zvmi_mGQsPl3Gjlh8B5TKlRbk3I4VUt3iA5dP-A3HhHOlgGk3Uso1anHxDwCxfjj44YBv9pWkx7QIOnAeMIOTaab0zFiZemaG5Hij7-4wOArTeuNPfeywfWE-y9rQ4CTiyRGLmLjzy-zA2j-WppHrhoXFoDmhe572SaLzbB--4yC0mc-UQWdUowe_unZbpMA=w1680-h945-no
i slike mrazom nastradalog
c6eYj8Dz2itrD2vqoMLJdZZe9h0OVvRFx_gO1mrd9bsI1lbGF9AMLwDiMYB4969LDgLC-d5q-NAheScFO5qjBK_s6FPc1kpbSJjXf7vpCyQMfBOXcacrmyDnKmnfYNIZoKFzQN5CkLp5zbjvHesqKadXgz01N3qSLtV2t2tPRfqsVUQ-troUd40Xkv511HNdHybU-sUx4Lj0PILn16lP4_uhBWBHbqV0i4QVB07OeQ5xLft9X8zPk55UiGDgOExQiiZcZn-Rp349_xwWU4dihEZiXCjvM6Sc4-NDnolvV5ETKLF5TdbWK4Jj7uxOdRptkDwK-ncygaxFaNACUrPpwLBRlx8fpCVQwtFMb2FmdETVMUpr54onEwZrR4cj1H_GENU8P7ZIA9WR5Kye0RsENKJCsONyorgj1_XJ6R6UuzE7L8Z1IxIf25V-LwXZVLCgPWuYCF7v8iAJnSYZYvlYq6RypqhppjtkoxDFW4ox7joR0-YnjFtHWkWKxSvvZ6gynsucFKaqcttC-gAukfg2E8gsB2AVoHGYcyzouepjhrVnztWctX0dptO3ph1R5VTSOAuwv-hUEBGuD1zN1e1lyjkKR5NI9hF-fNf523FKOoBS1kAAhQ=w1680-h945-no
6IoS0KnyepG5-dgaiPwYnXA4dHXgUL2R3gVYrp41r7jUOTU0jQuG3G6vaygvuBpwcMUFXJS3LqxTFwXqV2NeYnoXtkRrEXvR2nheM7rrBLvjLph71pNmPeNkMEA9Hxy1o36n9VBM7F43x2maxDEBMefyZaHSRqTKf9WlQvirS9x2yLx4I5C4U-xwkKNS9uGMzhhM_8X1nQQxI2sfJrfCCqgXcG6ja1T71_tiBoONR058-ujOHTS3dFsVIOfC8JeyZ1qkwQ9ehd4Ppa2XkNODQwM6RKF_gI-UgDlqW3Ypgcutamz61c_dWmVQpqiMSns5o8i-g-JLoL_Tpmcip58xnWnwfCqoT6Qavu2AkwctUV-_zD3Le7-GWVHrxsQpT3dES4wkl_3JiUpigGsbKZHkE9Lfb37m5RScivk7FOllHaXXrl4DBdYq7kCJssBGwrXdkPVy_wbuZnDNRaaRY_9r0vp-V0KQ5rXXyP991q4mconXekACWTdKTw8e58xTaaKIcypC_gXnXHNPvYhmWbIGlbK17ISy0oOvsNiszATN4pvi6dDxNge0hDoTX2ti9SCfB4acdShZFF9NyMfmO24RBySB2GiSuk7cW1h9SyNNxVdNpfJWhg=w1680-h945-no
PS, imat cu oko 450-500kg sivog pinot-a na prodaju i CCa 1000kg graševine.
Kakve se cijene očekuju ?
Krumpironja
7 Svi 2010
100e ko to radi? Ja bi isto taj koji ide napred, daj na pp di to mogu kupit
E sad je to lijepo ureden vinograd hhehe ja naseg necu ni snlikat sad haha
NEWHOLLAND
15 Srp 2010
Szr Duvnjak upisi u google.
Ako hoces nazad montiras si nazad. Mozes uzet i bez nosaca pa si sam napravis, naprijed-nazad kako hoces.
Nisam siguran jel 100€ sa ili bez nosaca. Njega sam si napravio za pola sata.
josix
8 Stu 2010
zwer covik, s cim si sprical i kada zadnji put?!
Sent from my Lenovo P70-A using Tapatalk
Krumpironja
7 Svi 2010
Ma mislim da to nije tesko ni doma napravit,dizni imam sve imam jedno popodne i složim si sam, ja cu stavit sebi napred a iza bazen i samo spojim na navoj umjesto spirice od bazena na ove napred i imam 300l otrova...
Ja sam mlade danas bio pofrezat
    82.5 KB · Pregleda: 98
zwer
15 Ožu 2010
Stari je šprical, mene ni ni blizu pa neznam točno...
U sutra bude 2 tjedna od zadnjeg špricanja, bil je samo nešto na bazi bakra jer je preletila tuča i peronospora se počela pokazivat
3 dana prije togabilo je nešto za zaštitu ploda...
Moram pogledat kad dođem doma kod staraca u bilježnicu, vode komplet evidenciju.
Krumpironja
7 Svi 2010
Sta je uzrok ovome, naletio sam na ovo danas, nije u našim vinogradima ali me interesira dali netko zna jel bolest ili greska u preparatima kod spricanja
    81.2 KB · Pregleda: 123
Plemeniti
16 Pro 2008
Meni se cini da se radi o prevelikoj koncentraciji sumpora pri previsokim temperaturama,,,
prvo bude kao vostana prevlaka a kasnije nesto slicno tome na slici,,,
Krumpironja
7 Svi 2010
Zlahtina...ono sta je ostalo od nje..vidis bobic toga se nisam sjetio, to treba pazit da a to je moguce posto vlasnik vinograda nije bas doma sa preparatima nego mu druge napisu i on samo složi i vjerujem da je pretjero jer samo u tom vinogradu mu je drugi je ok, izgleda da je razlika od bazena do bazena
Krumpironja
7 Svi 2010
Da vrlo vjerojatno ce bit spoj prevelike doze i temperature, a ja sam mislio da je to ona smeđa mrežica od pepelnice
josix
8 Stu 2010
ta žlahtina izgleda ko neki polu hibrid
Plemeniti
16 Pro 2008
Kod pepelnice uvijek neku bobu vise uhvati pa ona ispuca dok je na slici vrlo ujednaceno,,,
to me nagnalo na pomisao da bi se moglo raditi o problemima vezanim uz prevelike doze sumpora,,,
Krumpironja
7 Svi 2010
Josix ma ovo nema veze sa zlahtinom slikat cu ti ovih dana kako ozgleda normalan puni zdravi groz zlahtine
Da i obicno ispuca do kostice, a nisam cuo da je bilo problema sa pepelnicom tako da vjerujem da si u pravu, dobio si hvala, rijesio si me misterija hehe
