Građevinski radovi
Probaj najprije vidjeti sa kamerom :hahah:
Tak sam kod frenda imao problem, zapravo on i onda se ukazala prilika i kupio kameru na žici.
Znaš kak se za to veli u Srbiji?
Skuplja pita nek tepsija.
Sve se bu riješilo, ak ne drukčije, onda poptunim otvaranjem pločnika. ;)
N6ia6
25 Lip 2015
Htio bi u kokosinjcu poravnati zidove.Sad je na zidu grubi spric.Plan je da prvo operem zidove.Kupio sam i impregnaciju za zid.Mogu li nakon pranja i mazanja impregnacije samo ozbukati zid?Ili bi mozda trebalo baciti cementno mlijeko? 6:3:1 je dobar omjer pijeska vapna i cementa?
hqKh4LwvwNC4cQByp88GBjoRfzzBDCNhXRCKtJYXztktG5oCpOo8WlAjnKxrIO-lXi3K8PssChPLmjjkXzHXgY_voj-1BJ6j-9wZStsaMmUk2BVvc5YEsxkqjk34I-v5Yqr09jx-XGaCpk_sd-UVDk0iTI0q4oMgdr6B2vf2-DJXM4XUQYT7gpPA9SgkF6FnTkYAt88os3R4EwmOv7QSMp7AQjXWfWcm7oncKsq-bvcQBabKyogy3E9KtaZ8fCELTG--v2wx8YycvPOXLGfyzl6PiuUpvx9jc2domsDd0xoQ0QS3enrmsKy_KsW9nMrEfX05sp2B_pHTmB_pIzQ1-Szqk52R5g94Iu6oC5jB_Ri78fpFh5fGxasvGt1wlEv3zNXqRlGSp8rFrhAqfZzZksyyhIP3UZh1cFmyGAb8ojBhZfujQzYcOFdbviGiHie2i9DJjjHsHE6z9Wp5P-BApEptp9rg1X1CkcTPLXzUipJWcnPXXQ_ePzWLrKYoUsv5iHdxMSnze4rWX-EDUq_8yUXKq0sqDUQpzeBOiXYeYncH3pxxQ0a2HNQt0FK7feylZj2hWsP9XXtaizUPrUJuy-8xCdsAB4TZ0dzFcxKFi4xQpWBA8HNNjd-p_n9phxGZE_3vvfSg62BdquVB7kfvr90Kq2VYwTYQ5UsWz8IdBGbwSW76JiW8R7c5rdZZeFgJBp3x4kKVhdvGpoOXJkK0Thuof6rQRxhwpGP7MuQR2SgJpxX4e3s8KIp_pWe1TtX-47M2FmRY7E4PqS9WeLXuLbqVeZat4sRqEbS_o_jj_w4lZBQ7IBPUZc4vfI1yDh1cXMKctD0ohrx4MezaRW6Tj0bldd41suAXKcisiCNHvO4x0mj9A6MaXM3Divolp4rsbEQiFUt-JO84sIWcRsPjdKC6AY84J-mJg-ysbZVuuO5NwKX5lcihatDh0zpfbQMyh2FaLg=w2548-h1911-no
Wr27yH86VipI6huA_9flyMyUwsS7SWEgG7hQvFPE1AoyPEwbnkU_fM6Wbr8ccUcMrb-x5Ie_6cv7QLwew-Iau6GUVX0BHGE5nv0Ff-q12_DjIwAM-nFIDeT7aoBcLFX4uiWMTZoh41NWufNPGYeAVf0ShkiZq1jrMYqQQxpyunCaZMVu_9HM6ipyhuz3ObKWfuTq1hzzsSM99MlPgSwfjeUV6uT7kehEEyr3CWgZyFPe1rPLtEvfLpy8U97FGZOdK3SCDA-o016jHvEvWZE53NRM2hcWKlPPj4i65YpjOt7fmFLyO0YliHrbHGB7HpiZ1Q6YnmjIONAUqfU9LIgnvmj3PDhAB6VPJeHEzIWicgG-SDZECpYGdgZJ4Ze9Ov8o2MduEh3vTBvHpDhOd2jSWHWv9YbTSHtu1Su-riHPzXHH9s4IkMuQ0lfrEzOr6zqmLjs04Wa1yypeEeSp7OOjlONpU48kxKiPm_CtNFABDxZXCeMykdCKfIYrA_gNZT6xImH-gDJAuqUW5KBkFJgo3Pq5RsXvNS4DN5iMhpHegqs_EjUqNMfQtu9fSDp4jKB8Gzpy4Fc_ZnKVCdYb559BE85ntMQ5SZIRAu1qNNH_WpTiVqW3UjU83XONVguIecCjIE9IQgqpuacw-aCLOqLq_YSWx-kY6mDhKAMDUhwGP9hOZcNxI1jycA7i_NMaaydFmuuAMva6c14dzqhQ1IYr_M0ZpTvGwYdzG0xO5T_35Z_d8yTKL9MS9DqyW_xC60rY0eSdYqG2sLYIKMrLifAZWyHJs6PgJtdlc69WGMQtaLtgdDLZU-Lrx_mT69EdgdNs75zWcKQG0ZzrM0DSnB-CqySLCJ0wDmFevcV2Z6yTc6bz6bzYgvWSPr87qG4iovXGei8RRFRYlkhGx4FvULkOoB2DO3ZMdmXxCypgBJB0n73lRTHEvobXRCF8VaGoioJNnPvd4A=w2548-h1911-no
E ovako. Trebam jedan savijet.
Nakupilo se mehanizacije i šao mi da stoji po bašči. A nisam do sada bio u prilici napraviti prostor neki.
Nisam ni sada baš, ali jednostavno moram nešto napraviti.
Označio mi kum i napravio nivelir kartu za 8*12 iskop.
To sam mislio prvo nivelirati jer je blagi pad, pa onda ispod 0 iskopati 10-20-30 cm i nabiti kamen vibro pločom i sa strane rubnjake.
Sad prvo pitanje
koliko debel mora biti sloj kamena?
Ja sam mislio 20 cm iskop i toliko kamena. Kum viče ništa ispod 30. Na internetu gledam da ljudi po 10 cm sipaju i to valja. Neće gore ići nikakva deka ni opločenje. Kamen čisto da mehanizacija nije na zemlji i da mi se ne stvara blato.
Iskopao bi na jednom kraju temeljne stope za 6 stupova i napravio nadrstrešnicu 5 duboku i 8 široku.
Znači 5*8 nadstrešnica i 7*8 predprostor za par priključaka što ne moraju biti unutra i pranje traktora i tako. Generalno ravna podloga koju nigdje ne posjedujem
Ispod bi stavio geotekstil i onda navezao kamen. Koliko kamena ??
Najprije napravi krov. Onda uvezi strojeve. Oni će napraviti kanale i tada budeš vidio koliko je tlo mekano i moći ćeš ocijeniti koliko trebaš navesti kamenja
Ma goldoni je 2 tone. Ne pravi on baš kanale ni ovako po mokrom. Malo kod skretanja i manipulacije priključaka.
JOHABI
14 Velj 2011
Nije da sam stručnjak, nije da se razumijem, ali 20 cm je puno premalo mislim ja.
Ja računam da će naići pokoja zimska zima ko što zima zna biti, ona sa -15, -20, kada se sve smrzava na 30 cm i dublje, pa se diže, pa popuca ko od keksa beton. Ja bih to ne samo sa minimum 30 nego i 40, a i sa mrežom barem osmicom, zapravo desetkom.
Ali ima tu znalih znalaca majstora, pametnijih od mene jedne žemske ženske, pa će oni reći neku pametniju. :)
Neće gore ići beton. Samo kamen i svakih 10 cm nabijanje vibro pločom.
Našao sam na balkanski način jeftin kamen. Rade par km od mene novu cestu... Tako da će ići 40 cm gore 😁😂
Valjda dolje? 🤭 🤣
Ne znam više šta je gore šta je dolje...
Pošto su planirani radovi na vrh voćnjaka... A kad je ovako vrijeme malo se problem popeti. A kamen mogu dobiti jeftino... Radim 100m privatnog puta.
2.2 m širok, 20cm kamena gore.
Znači zapitam se šta je meni ovo trebalo. Fali meni cijeli plot u glavi, a ne daska...
Između puno iskusnih znalaca možda se bu našel netko tko bu mi pomogel. Delam izolacijsku fasadu i mijenjaju se prozorske klupčice. Dvoumim se između aluminijskih i kamenih (granitnih). Kamen mi izgledaju ljepše i djeluju otmjenije. Ono kaj mi smeta kod njih je cijeđenje vode na krajevima klupčica po zidu i time s vremenom ostavljanja zmazanog traga na zidu. Aluminijske imaju na krajevimazavršetke koji to sprečavaju, ali buju sigurno dosta skuplje ako su u nekoj drugoj boji osim bijele. Naime širina 40 cm koje trebam, se dela samo u bijeloj boji i trebalo bi je dodatno plastificirati u željenu nijansu.
Čul sam dva prijedloga za sprečavanje cijeđenja vode po zidu kod kamenih klupčica:
1. zarezati na gornjoj strani koso utor kojim bi se voda usmjerila dalje od kraja klupčice.
- ne dopada mi se baš preveč, jer mislim da utor nebu tak glatki kak je ostatak klupčice, a i pitanje je efikasnosti odvoda vode.
2. Nanošenje silikona visine 2-3 mm uz rub klupčice.
- silikon upija zmazanoču i bojim se da bu to kroz nekoliko godina ružno izgledalo.
Postoji li neki efikasan i trajno funkcionalno i estetski prihvatljiv način za sprečavanje cijeđenja vode po zidu?
Jel nema onaj kanal što se ureze duž cijele klupčice. Okapnik kažu ako se ne varam?
Imaju taj kanal, ali on rješava problem samo s prednje strane klupčice, ali ne i na bočnim stranama iz sam zid.
jlukaci7
1 Velj 2012
treba biti kanal na bočnim stranama klupčica ali sa gornje strane klupčice poslikam sutra ako treba
Znam otprilike kako treba biti izveden (koso na uglu da vodu odvede prema sredini klupčice), ali ne vjerujem baš u efikasnost (vjetar) i površina kanala (ureza) vjerojatno ostane hrapava, a ne glatka kao ostatak klupčice.
