Uzgoj lijeske
Plemeniti
16 Pro 2008
Da istina je to sa tvornicom pod vedrim nebom,,,
prednost koju ja tu vidim je sto imas gotovu armaturu za protugradnu zastitu,,,
Nisam 100% siguran da je ovo sto sam nasao na americkim stranicama isti dio teksta kao i kod nas pa sam zato trazio potvrdu u zavodu za intelektualno vlasnistvo,,,
Kopirat cu samo dio koji je zanimljiv a tice se zastite (nazalost na engleskom je jeziku pa ce neki morati potegnuti za prevodiocem preko neta,,,
The invention claimed is:
1. A method for the cultivation of at least one hazel tree
with a crown having the form of a vertical spindle on a support
in a fully developed state, comprising the steps of:
planting at least one hazel tree seedling and allowing the
seedling to grow and form a hazel tree with a branch;
pruning by splitting the branch within the ?rst year of
planting to form two sub-branches.
2. The method according to claim 1, wherein a plurality of
hazel tree seedlings are planted in two parallel rows with a
distance of 3 to 5 meters between the two rows; wherein the
seedlings within each row have a mutual distance of 0.5 to 1
meter.
3. The method according to claim 2, wherein the support
comprises a plurality of support frames, wherein each support
frame is provided at an end of each row; wherein each support
frame comprises a vertical pole and a plurality of horizontal
cross-bars; wherein a wire connects ends of corresponding
crossbars of the support frames within the same row.
4. The method according to claim 3, wherein the vertical
poles has a height of 3 to 5 meters above ground, and are
spaced apart 5-10 meters in one row; wherein the horizontal
crossbars are spaced apart 0.5-l meter along one vertical pole.
5. The method according to claim 1, wherein during the
whole life cycle of hazel tree, manual and/ or machine pruning
by splitting of the branches and the crown is carried out at
least once a year.
6. The method according to claim 5, wherein the hazel tree
in the fully developed state has a vertical cylinder shape of
uniform cross-section, with a height of 3 to 5 meters and a
diameter of 0.5 to 1 meter, with a skeleton consisting of:
a central branch,
radially arranged primary branches attached along whole
height of the central branch each with a length of 0.2 to
0.5 meter,
secondary yielding branches attached to the primary yield
ing branches each with a length of 0.2 to 0.8 meter.
7. A method for the cultivation of at least one hazel tree
seedling to grow and form a hazel tree with a branch of
one year old;
pruning by splitting the branch of one year old during the
period between the frst year and the second year of the
planting to form two branches of two years old;
pruning by splitting at least one of the branches of two
years old during the period between the second year and
the third year of the planting to form two branches of
three years old; and
pruning by splitting at least one of the branches of three
years old during the period between the third year and
the fourth gear of the planting to form two branches of
four years old;
wherein the branches of the hazel tree are tied to the sup
port at different heights.
8. The method according to claim 7, wherein the hazel tree
a central branch,
0.5 meter,
9. The method according to claim 7, wherein a plurality of
meter.
Pa zar je moguce da covijek ulozi milijun kuna u patent i onda ostavi tako sirok prostor za manevriranje (vidi boldano pod tockom 9.)
Sto bi znacilo da se bez ikakvih problema moze posaditi red udaljen od reda 295 cm u sirinu ili 105 cm razmak u redu a da nisi duzan podmiriti troskove zastite intelektualnog vlasnistva,,, :icon_scratch:
Da se razumijemo nije mi bio cilj traziti rupe u opisu vec mi je bilo cudno da se covijek koji je spreman uloziti tolike novce u zastitu necega ne pobrine da se to nemoze zaobici,,,
Mene je vise zanimao tehnoloski opis onoga sto je patent obuhvaca,,,
Jos uvijek postoji mogucnost da ovo nije cijeli dio teksta koji opisuje patent,,,:(think):
karla
20 Ruj 2008
Uh, Bobiću teška ti je tema s tim intelektualnim.... daj ti nama nešto jednostavnije konkretnije. što se dešava kod tebe s problematičnim stablima, dali su se oporavila ili skroz osušila, da li si radio neku specijalnu zaštitu u tom pogledu. Imam nekog malog iskustva u toj problematici pa da podijelimo.
Plemeniti
16 Pro 2008
Buduci da nisam bio nacisto sta cu sa tim napraviti prepustio sam to vremenu da ono odradi svoje,,,
I odradilo je:(nod):
Na moje veliko iznenađenje biljke su se oporavile iznenađujuce dobro, lisna masa se obnovila a i na mnogim grancicama vide se i rese sto bi moglo znaciti da bi vrlo vjerovatno moglo biti i rodnih pupova pa bi se na tim mjestima sljedece godine mogao ocekivati i urod,,,
Ja zaista vise neznam sto napraviti,,,
Jasno mi je da su to postrani pupovi i da se na tome nemoze temeljiti neka ozbiljna proizvodnja ali kako se cini u tim biljkama jos uvijek ima dosta velikog potencijala,,,
Uz ta problematicna stabla ostavljeni su i mladi izdanci (tamo gdje su potjerali) pa ce se do zime donijeti odluka o tome dal se ide u glavu ili im se pruza jos jedna sansa,,,
Na plantazi imam vise tih problematicnih dijelova kod kojih je izrazena oscilacija u duzini ljetorasta i nisu svi na depresijskim podrucjima, kod nas to zovu pregoni,,,
to obicno bude poprijeko parcele u sirini od nekoliko metara u liniji gdje je evidentno da nesto nije u redu,,,
I nakon 7 godina jos uvijek nema rijesenja kako to popraviti jer i novo zasađene biljke na tim mjestima ne napreduju kao sto nisu napredovale ni ratarske kulture kad su tu rasle,,,
No radit ce se i na tome,,,:(wasntme):
Sljedece godine opet ide zemlja na analizu pa cu problematicno podrucje staviti kao poseban uzorak da vidim u cemu je problem,,,
Jer kad ide uzorak sa 20-30 mjesta i kad se isti pomjesa nemoze se dobiti stvarna slika problematicnog podrucja vec se dobije jedan prosjek a to nije to,,,
Bilo bi mi drago da podjelis svoja iskustva pa bi na temelju njih mozda bilo lakse donijeti odluku o tome sto napraviti u konacnici,,,
Naravno i komentari i iskustva svih drugih uvijek su dobrodosla,,,
Samo da dodam, nikakva posebna zastita ili prihrana nije rađena na problematicnom podricju vec se cijela plantaza tretira jednako,,,
Jučer sam obišel mlade lijeske i evo dvije fotke.
Ovojnica ploda je na nekima djelomično posmeđila. Kaj bi to moglo biti?
Imam malu količinu i nisu s ničim tretirani.
Plemeniti
16 Pro 2008
Ako je samo palez na ovojnici onda nije problem a ako smeđi i ljuska onda jest problem ali nema pomoci,,,
Veci problem predstavlja onih nekoliko suhih,,,:(emo):
Runa
9 Srp 2015
Hmmm, cini se da ti imas khmhmmm, jel,,,,
da ne kazem muda jel,,,,
hehe, ma nije toliko stvar u mudima i onim drugim, vise se radi o tome da zelim krenuti sa plantazom kako bih si 'osigurao' nekakvo relativno osrednje primanje, a da bi to omogucio samo po pitanju teorije potrebno mi je otprilike 7-8 ha pod ljesnjacima, iako sam veliki ljubitelj oraha :icon_super:
radi se samo o tome koliko uloziti i sto ocekivati, naravno, veci ulog osim veceg prinosa nosi i vece rizike, zato sam i napisao da razmatram, savjetovat cu se, obici plantaze, uciti jos...dakle ove godine nikako ne, nagodinu svakako da, po ovom ili onom pricipu uzgoja.
zna li netko od Vas kako se uopce zatrazuje poticaj, konkretno iz eu ali i hrvatske i konkretno za ljesnjak? sto mi je ciniti?
i sta je sa ovim novim poticajnim mjerama tzv 6.3 ? tu se navodno moze za malo poduzetnistvo odnosno u ovom slucaju vocarstvo, dobiti nepovratno i do 15 000 eura, i to navodno se u natjecaj moze ici samo sa dobrim projektom, ne mora se nuzno niti posjedovati zemlja vec kupnja iste bude dio projekta, jeli to moguce?
Plemeniti
16 Pro 2008
Mislim da je za to istekao rok 12. srpnja 2015.,,,
vidi na stranicama resornog ministarstva tj agencije za pprrr.
Hvala Bobiću.
Na kaj si mislil kad spominješ suhe?
Plemeniti
16 Pro 2008
Na ostale slike iz albuma,,,:(emo):
Ako se ne varam tamo se vidi nekoliko komplet osusenih,,,:icon_scratch:
Runa
9 Srp 2015
itekao da, hvala na odgovoru.
a dali se isplacuje na godisnjoj bazi 2,500 kn po hektaru za odrzavanje dugogodisnjih nasada / ljesnjaka plus 600 kn / ha za uzgajanje domace sorte / istarski ?
Plemeniti
16 Pro 2008
Naravno ako podneses zahtjev za poticaj,,,
sjednu i novci na racun ako nemas neki dug prema drzavi a ako imas onda agencija radi prijeboj,,,,:tongue:
Zbilja si vrijedan. :icon_biggrin: :icon_super: Nisam očekival da buš pregledal album. :icon_surprised: Još jednom hvala.
Dvije su se osušile, a jedna stradala kod košnje. Planiram na jesen uzeti mlade izboje i presaditi. Nadam se da bu uspjelo.
smiki
6 Lis 2014
Ima li svrhe , da li vrijedi na ovim vrelim danima ici folijarnu prihranu?
izgibo zalijevajuci
Žarko
6 Stu 2011
U kasnu jesen i rano proljeće navezao sam stajnjak oko voćaka ali ga nisam zafrezao u zemlju. Krajem svibnja špricao sam travu ali sad je izbio koštan kao gora pa savjetujem da ukoliko netko planira isto neka se pripremi na duplo špricanje ili trimeranje.
JAROMIR
27 Velj 2010
Kakovo je ovo zatišje na temi jeste li možda počeli sa sakupljanjem. Imal li kakovih saznanja što se tiče eventualne cijene ovogodišnjeg roda.
pozdrav.
igru
11 Svi 2015
I ja se danima pitam, gdje su svi.Mi smo lagano poceli sa potkupljanjem, a mislim da cemo uskoro u berbu.Sto se cijena tice vrtoglave su i u trznim centrima i na pijacama.
djomla
25 Srp 2015
Pozdrav,
Interesuje me mišljenje "starijih" kolega o stanju sadnica u drugoj godini?
Suša nas je dosta namučila, ali smo išli pet puta sa zaljevanjem po cca 20 litara po sadnici. Inače su sve tretirane po ps-u, od đubrenja do zaštite. Mala je parcela, pola hektara, sa posađenih 330 stabala u razmaku 5x3 i proširivaće se još za nekih 200 komada sadnica.
Dali je prirast zadovoljavajući? Imali smo i nešto roda :icon_wink:
dejan.pfos
4 Tra 2011
Po meni super izgleda ako su sadnice bile jednogodišnje kad ste ih sadili... eto čak i ploda imate, što ja recimo nisam imao do 4-te godine s jednogodišnjim sadnicama
