Malčeri
danek
18 Pro 2008
Re: malčeri
tu travu samelje i obična kosilica,daj nekaj tvrđega i debljega probaj
seljačić
8 Velj 2009
Re: malčeri
danek kaže:
ma znam da to i kosilica odradi,i znam da nešto deblje nije problem za malčere sa čekićima,meni je bilo bitno da vidim šta takav malčer radi sa travom tojest kako obrađena površina izgleda. za mene izgleda jako čisto i bez ostataka trave i viših slamčica.to mi je bilo bitno da vidim jer na snimcima u youtube se slabo vidi kako travnjak nakon malčera stvarno izgleda.da lomi granje to smo dosta puta vidjeli.
spyder
18 Ruj 2008
Re: malčeri
idem ja sad snimiti svoga pa postam na youtube, sad je stari otisao malcirati
seljačić
8 Velj 2009
Re: malčeri
spyder kaže:
super,samo naprijed
spyder
18 Ruj 2008
Re: malčeri
[youtube:j1c441zk]<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/wQb4HgnDYjs&hl=en&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/wQb4HgnDYjs&hl=en&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>[/youtube:j1c441zk]
[youtube:j1c441zk]<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/uYOWq4TSirE&hl=en&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/uYOWq4TSirE&hl=en&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>[/youtube:j1c441zk]
[youtube:j1c441zk]<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/WMg6bfhV1Ak&hl=en&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/WMg6bfhV1Ak&hl=en&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>[/youtube:j1c441zk]
na prve dvije snimke se vidi dio nasadfa koji je jućer malćiran, a na trećoj je mladi nasad sađen proljetos tu njiva nije skroz ravna ima dosta ispropadanog kolotraga od cisterne što smo proljetos zalijevali pa ga nemože idealno ravnomjerno pokosit, morat ću najesen to sve dobro istanjurat da se izravna, inaće prvu i drugu godinu sam kosio ovaj stariji nasad sa posuđenim helikopterom i kažem vam da je nula spram ovoga
seljačić
8 Velj 2009
Re: malčeri
spyder kaže:
[youtube:1wz9201z]<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/wQb4HgnDYjs&hl=en&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/wQb4HgnDYjs&hl=en&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>[/youtube:1wz9201z]
ko stadion. :D
kako je izgledalo prije?
I kako si ubacio ovaj snimak da se direktno sa foruma može vidjeti a da neidem na youtube????
Re: malčeri
I kaj je ovo prema bobine sikare od 2 i kusur metara :scratch :scratch ovo kosi obicna rotaciona kosilica od 200 kn
spyder
18 Ruj 2008
Re: malčeri
o da vidiš kako to kosi šikaru kad budem išao u šumu tarupirat šljunkarice snimit ću, samo ga onda ne vuće fegruson, a sa rotacionom kosilicom od 200 kn nemožeš baš 10 jutara pokosit za dan i što je razlika od helikoptera što ovo stuće dobrano travu i duže joj treba da se oporavi, opet vam kažem kosio sam i sjednim i s drugim iz moga iskustva ovo je nemjerljivo sa helikopterom pogotovo kad se ide radit šikara jer ovaj samelje sve
josip123
3 Svi 2009
Re: malčeri
evo kako se malčira u susjednoj mađarskoj na prezentaciji jučer.
Re: malčeri
Pa jasna stvar da se helikopter ne moze mjeriti s pravim malcerom, al za novce koje u helikopter trebas uloziti, Decki moji, ja sam SUPER ZADOVOLJAN, al totalno ;)
Malo pokretnih djelova, malo potrosnog materijala ,odrzavanje se svodi na pranje i ostrenje nozeva, te u dogledno vrijeme zamjena istih...
Malcer s Y nozevima radi poslove s kojima se helikopter muci, al za isti radni zahvat 28 nozeva, pa ti njih ostri, pa kad ih treba mjenjati opet lupa po dzepu... Cekici su druga stvar jer ih ide duplo manje, al 100Kn komad dodje ti da se zamislis. koliko samo das u odrzavanje malcera, helikopter ce ti visestruko vratiti, na kraju ga bacis i odes po novi i opet si u plusu.
Imam i ja vuceni malcer s nozevima od kukuruznog beraca, ide sa strane traktora pa ga tjeram u sikaru gdje se ne bih usudio ici helikopterom, jer traktor mora ici ispred. malcer je divlji stroj i samo mlati sve pred sobom.
kako sam i sam rekao, ak se ima mogucnosti, svakako kupiti pravi malcer, jer je to stroj koji je bas namjenjen za sve uvjete rada, dok je helikopter vise kosilica, nego malcer...
Smiljan
5 Ruj 2007
Re: malčeri
Tocno Bobo. Tesko je usporedjivati nesto sto kosta 5-6 tisuca kuna sa necim sto kosta 15 ili vise tisuca, za isti radni zahvat. Kao kad bi se islo usporedjivati Tehnostrojka sa gumenjakom :)
spyder
18 Ruj 2008
Re: malčeri
i ja se potpuno slažem sa vašim mišljenjima, jos bi nadodao da čekići puno duže traju od recimo noža, htio sam samo pokazati i drugu stranu jer vidim da se seljačić dvoumi pa sam mu htio pokazati, a naravno da nije isto ni ulaganje i ja sam opet kažem prve 2 godine kosio sa helikopterom i nemogu reći da nije služio svrsi
Smiljan
5 Ruj 2007
Re: malčeri
Stvari treba gledati sa vise strana i osobne potrebe/mogucnosti/zelje
seljačić
8 Velj 2009
Re: malčeri
Smiljan kaže:
istog smo mišljenja,
i uz pomoć vas sviju ovdje ja se približavam svojoj odluci.čim šta bude dobićete rezultate moje odluke i naravno sa terena.
josip123
3 Svi 2009
Re: malčeri
Bobo kaže:
slažem se sa tobom u potpunosti što se tiče svega osim cijene čekića.ja sam ove godine za svoj TFZ 190 kupio nove čekiće i platio sam 48kn komad,čini mi se da u lateranu košta 89kn i to isti.mislim da i stroj kao što je tvoj može da zadovolji ali tko ima puno malčiranja i tko ide recimo da malčira agaciju bilo bi mu pametnije da si kupi malčer sa čekićima.kada sam ja svoga kupio platio sam ga 19000kn sa kardanom i već sam ga drugu godinu otplatio.do ove godine sam radio usluge sa njim a sada mi se to više ne radi pa odem samo prijateljima.prošlih godina su me ljudi morali i po tjedan dana čekati da im se izmalčira trava jer kod nas više nema stoke,a trave ima ko u priči pa ljudi plate malčiranje i nemaju brige šta će sa tom travom.sada bih svoga možda i prodao pa bi si kupio onaj sa kranom da mogu kositi kanale oko njiva. ;)
tine
10 Pro 2006
Re: malčeri
josip123 kaže:
Ovaj?
Šalji mi adresu da ti pošaljem ponudu. :mrgreen: :mrgreen: :mrgreen:
josip123
3 Svi 2009
Re: malčeri
to je za mene ipak preprofesionalno.trebam nešto manje jer kod mene nema tako dubokih kanala a gdje ih i ima tu prođem samo jedan trag.
Re: malčeri
Jel netko probal s "helikopterom" malčirat kukuruzovinu? Kakva su iskustva?
