IMT 539 i 533
Pjero
22 Stu 2010
Kod mene na 539... 8 kom
Ove sam montirao prije 3 g. na savjet push pulla od ZJ od prije 15-tak godina.
Takve skupe spojnice idu samo na zelene traktore ;)
Odnosno tam gdje su spojnice ugrađene neposredno na razvodniku.
Ako ja mogu imati takvu spojku ugrađenu na preši koja je kombinacija crvene i srebrne boje onda nije problem ni Fergusona u zeleno pofarbati.
Nije to danas više tak skupo, a ni ne mora biti neposredno na razvodniku ugrađeno.
Ne mora, ali obično je.
A i bilo je zelenih IMTa 549 z Torpedo motorom ;)
zveroboy
26 Tra 2025
The string
"IS 2172-M12 x 1,5" refers to a specific type of fastener or threaded component, typically a bolt, nut, or stud with metric threading.
Here is a breakdown of the designation:
IS 2172: This is likely a standard or part number designation from a specific organization or manufacturer, possibly related to a local standard in some regions (e.g., India Standards, or in this context, potentially JUS/Yugoslavian standards, as it appears in a document alongside other JUS and IS standards).
M12: This indicates a metric thread with a nominal diameter of 12 millimeters.
1,5 (or 1.5): This indicates a fine thread pitch of 1.5 millimeters. A standard M12 thread would typically have a 1.75mm pitch.
Matica kojom se sarafi truba (kuciste poluosovine), na centralno kuciste, na IMT539, izgleda nije standardna kakva se moze kupit u zeljezari. Probao sam oprezno, standardne matice M12, i ne odgovara. Uglavnom razlika je vidljiva u zadnjoj recenici onoga sta je gore pejstano.
"1,5 (or 1.5): This indicates a fine thread pitch of 1.5 millimeters. A standard M12 thread would typically have a 1.75mm pitch."
M12x1.5 vs M12x1.75
refers to metric bolts with the same 12mm diameter but different thread pitches: M12x1.5 is a finer thread (closer threads), while M12x1.75 is a coarser (standard) thread with more space between threads, meaning they are not interchangeable and will not fit each other without damaging threads.
Key Differences Explained
M12: Both fasteners have a 12mm nominal (major) diameter, the width of the bolt's shank.
Pitch (x1.5 vs. x1.75): This number is the distance between adjacent thread crests, measured in millimeters.
M12x1.5 (Fine Thread): Threads are closer together (1.5mm apart).
M12x1.75 (Coarse/Standard Thread): Threads are farther apart (1.75mm apart).
Why They Don't Mix
Using the wrong pitch will cause problems:
M12x1.75 into M12x1.5 hole: The coarser threads will try to cut into the finer threads, stripping them and ruining the fastener or the threaded hole (like an oil pan).
M12x1.5 into M12x1.75 hole: The fine threads won't properly engage the coarser threads, leading to a weak, unreliable connection, or it might not even start.
In essence, think of it like trying to fit a wide-toothed comb into a very fine-toothed comb's slot – they don't match up correctly
To matica je izgleda na linkovima dolje dostupna, ali to su izgleda u Sloveniji trgovine.
Ta matica ide na ovaj brezon.
Budem nazvao u Jozic, ako imaju brezon, mozda imaju i maticu za njega u ponudi.
Nasao sam i ovo, budem probao prvo to, na prvu moglo bi odgovarat jer je M12x1,5 specifikacija.
Ali izgleda da je ovo bas odgovarajuca matica, sta mi treba.
Eto, mozda nekom drugom pomogne.
Nabavi si one špijune za mjerenje navoja. Ne koštaju puno, a možeš si sam provjeriti o kakvome se navoju radi.
Za navoje (vijke i matice) koristi se više standarda, zavisno od zemlje, namjene i vrste navoja. Evo pregled najčešće korištenih standarda:
🌍 Međunarodni i evropski standardi​
ISO (International Organization for Standardization)
Najrašireniji standard danas.
  • ISO metrički navoj (M) – npr. M6, M10
    • ugao profila: 60°
    • korak može biti grubi ili fini
  • Standardi: ISO 68, ISO 261, ISO 262, ISO 724
👉 koristi se u Evropi, većem dijelu svijeta
DIN (Njemački standard)
  • Praktično isto što i ISO, stariji nazivi
  • I dalje se često koristi u tehničkoj dokumentaciji
  • npr. DIN 13 (metrički navoj)
🇺🇸 Američki standardi​
Unified Thread Standard (UTS)
  • koristi se u SAD-u i Kanadi
  • ugao profila: 60°
  • izražava se u inčima
  • tipovi:
    • UNC – grubi navoj
    • UNF – fini navoj
    • UNEF – vrlo fini
  • npr. 1/4–20 UNC
ANSI / ASME
  • Tehnička regulativa za UTS navoje
  • npr. ASME B1.1
🇬🇧 Britanski standardi​
Whitworth (BSW, BSF)
  • ugao profila: 55°
  • stariji standard
  • danas uglavnom kod starijih mašina
BSP (British Standard Pipe) – cijevni navoj
  • BSPP – cilindrični
  • BSPT – konusni
  • koristi se za cijevi i hidrauliku
🔧 Cijevni navoji (međunarodni)​
ISO cijevni navoji
  • R / Rp / Rc (prema ISO 7)
  • za zaptivanje fluida
NPT / NPTF
  • američki cijevni konusni navoj
  • često u hidraulici i pneumatiki
⚙️ Posebni i namjenski navoji​
Trapezni navoj
  • Tr (ISO) – npr. Tr20×4
  • za prijenos sile (vretena, dizalice)
ACME
  • američki trapezni navoj
  • ugao: 29°
Kvadratni navoj
  • vrlo efikasan, rijetko se koristi danas
Okrugli navoj (Rd)
  • za prljava okruženja, lampe, spojnice
🧪 Ostali standardi​
  • JIS – japanski standard
  • GOST – ruski standard
  • NF – francuski (uglavnom zastario)
📌 Kratak sažetak (najčešći)​
StandardPodručjeTip
ISO MGlobalnoMetrički
DINEvropaMetrički
UNC/UNFSADInčni
BSPUKCijevni
NPTSADCijevni
Uz te standarde ima i "kurvinskog posla"!
Neki tokari naprave navoj da kad se ošteti moraš doći samo k njima? Jedino oni imaju kombinaciju zubčanika za takav navoj.
Matica koju ti trebaš je M12x1.5. Neznam odakle si ali bolje opskrpbljena željeznarija bi to trebala imati.
Ili kakav dučan dijelovima.
Toga bi trebal imati i lokalni automehaničar jer takve matice se koriste na kuglama, nekim krajnicima.... a sa novima obično dođu nove.
Kaj se tiče češlja za navoje kojeg Lijeska spominje.
To je korisna sprava ali može i zavarati. Ne zove se badava češalj za brzu kontrolu navoja.
Bude. Tam iza, gdje je nareckano, imsš šlice za razne debljine lima, pa poglegaj koji ti paše.
Ovaj šlic, kak je sad postavljeno, je za poklopac.
je, to je majstor stavil gore...bum probal pomaknuti segere iza...inače sam imal gumene ali moram sad staviti poklopca jer s gumenim nebrem pomaknuti spojnicu...
Kad pomakneš seger onda buš najvjerojatnije trebal još dva segera jer ako dobro vidim sad ga napred nema.
Ako ti je šlic preširok, a baš ti taj paše možeš razmak ispuniti pločicom odgovarajuče debljine ili navlečeš gore jedan ili dva segera pa tek onda onaj u utor.
imam s oba dve strane segera samo se ne vidi na sliki....ali moguće da bude predebeli šlic za jedan seger...nekaj bum smislil...
Pogledaj na onoj mojoj slici, na stranici prije. Montirano je tam negdje pri kraju, a nosač je 3...4mm debel.
Vidim da imas ipak one gumene zastite...more se nataknuti to na push pull? Jer na obicnoj sam moral poteci isto kak da.cijevi stavljam
Isto tak. Idu dok su nove i mekane.
Za skidanje ih samo povlečeš, a za postavljanje treba rukom gurnuti zadnji dio spojnice/crijeva malo naprijed i onda postaviti i pustiti spojnicu.
